Spiralize Contour Weirdness
Nicolinux
Posted · Spiralize Contour Weirdness
I wanted to print this object (link) and decided to do a few test runs with a scaled down version. I activated the "spiralize contour" setting because the object looks almost like a lamp.
The thing is, with this setting on the printed object exhibited the same artifacts that one would identify as banding:
Shy Light 01
The weird thing though - gcode preview in Repetier Host showed it as well!
1Shy light 12.5cm 2mm Eno
As soon as I deactivated spiralize contour the object printed fine.
Shy Light 02
2Shy light 12.5cm 2mm Eno
Well not fine because on one object the printer decided to underxtrude just one layer... (I printed two at once, one after another).
Shy Light 03
So my question is, how can this happen? I may need to rethink my whole "wobble banding" issue because it seems that under some circumstances this artifacts are added by Cura.
    As I understand it, sprialize *only* works properly for an object where every slice is a single closed polygon. So this works great for vases and cups. Also it will only do a single pass on this polygon wall so if you ask for a .8mm wide wall and you have a .4mm nozzle it will be basically extruding at 200% flow. Also it will not print a top.
    The part you show here - if you slice it is more like to curve segments that don't meet. It is nothing like a polygon.
    Another rule of thumb: spiralize and retraction should never occur on the same part.
    Spiralize contains a bug if comes across multiple islands. I've fixed it for the next release, so that might be your troublemaker here.
