Use CURA without GUI?
j.doe
Posted · Use CURA without GUI?
hi guys and
first of all: happy new year!
here's my problem in one short sentence:
i'd like to start the print of a simple ball via a button on a website.
for this i thought of running a little program on the server after having recieved the information ("button clicked") from the website. the program should manage to start the 3D-print of the "ball.STL" automatically. this means i'd have to give cura all the print-parameters and information with some (console-?)commands.
unfortunately i'm barely familiar with the functions of cura and to be honest i've no idea what kind of programming ist required to start other programms like cura with a self-written programm. i've heard something about batch-files...?
in a nutshell:
is there a way to run cura and its functions without the GUI? like a console-input... (i coulnd't find a topic refering to something like that)
any ideas/information? thanks,danke,grazie,merci...
markus
    thanks a lot for the fast answer Daid!
    but is there a more detailed description somewhere? The cura-manual does not mention this possibility, as far as i know/scanned the content :???:
    for example concerning the following questions:
    - which file/exe would i have to address?
    -how would the console-code look like? what is the output-filename for? the generated gcode?
        • 2 replies
