Tu fais un mur de 0.4 : cura passera deux fois.
Tu fais un mur de 0.8 : cura passera deux fois également, une fois pour le mur intérieur, une fois pour le mur extérieur.
Tu fais un mur de 1.6 : cura passera 4 fois
Tu fais un mur de 2.4 : cura passera 6 fois
etc, etc...
Attention cependant au diamètre réel de la buse qui sur les Ultimaker est "pondéré".
Ex. une buse de 0.4 sera de 0.35 sous CURA...ce qui change les calculs
S-Line Firmware 8.3.0 was released Nov. 20th on the "Latest" firmware branch.
This update is for...
All UltiMaker S series
New features
Temperature status. During print preparation, the temperatures of the print cores and build plate will be shown on the display. This gives a better indication of the progress and remaining wait time. Save log files in paused state. It is now possible to save the printer's log files to USB if the currently active print job is paused. Previously, the Dump logs to USB option was only enabled if the printer was in idle state. Confirm print removal via Digital Factory. If the printer is connected to the Digital Factory, it is now possible to confirm the removal of a previous print job via the Digital Factory interface. This is useful in situations where the build plate is clear, but the operator forgot to select Confirm removal on the printer’s display. Visit this page for more information about this feature.
darkdvd 975
En théorie, c'est X fois le diamètre de la buse.
etc, etc...
