Thanks for the reply.. All my problems printing were using Formafutura frosty white 3mm PLA filament. I did measure the material and it was in the range 2.95-3.05 mm. When I changed to a PLA on the 2.78-2.90 mm , I sid not have more problems.
I could not manually extrude even when the temperature reached 210.
thanks,
Mario
IRobertI 473
You can't use filament over 3mm in diameter, that's a mechanical limit. That is, the material simply can't pass through the printer if it's too big.
Yeah the time estimation on the display is way off. I can't remember the exact algorithm it uses but basically the estimate gets better the longer the print has been going on. I believe something is in the pipeline to help with this. On the plus side the estimate in cura 13.12 is now quite exact so you can trust that instead.
Manual extrude. You were in the correct menu. Did you wait for the hotend to get up to temperature? Once it's hot enough you'll be able to move material by spinning the button.
The excessive retraction of filament after an aborted print is a known bug and has been fixed for the next release. It should be available soon.
edit: If you don't want to wait for an official update: https://groups.google.com/forum/#!topic/ultimaker/tDKAHxe8rI0
