Upgraded to Cura 4.9.1. Found some bugs in 4.9 but did not reach to report them before 4.9.1 came out.
Tip to others who might do the same, don't uninstall the original Dremel slicer. Why? Because every time
Cura is updated You got to do the same copy of Dremel files to the Ultimaker Cura new version.
Beware the support ZigZag pattern may cause nozzle clogging on circular parts with small overhangs.
Struggled a lot before I realized this ...
So don't wast time doing a lot of useless fix like this dude
Ohyst60 2
The 3d print came out just fine! I will definitely continue using 4.9.
Got to transfer all required profiles, hopefully 4.9 will accept those
with 0.3, 0.2 and 0.1mm. Maybe the trick would be to increase 0.05
to 0.2 temporary and then import ... stupid me ... it was a bit late ...
to my excuse!
