Posted
· Cura 4.8.0 ignores hotend temperature settings
Have you been able to print anything? Within your gcode file should be an M104 and/or M109 to set the hot end temperature. M109 is "wait for hot end" to get to temperature and the M104 merely sets the temp. They need to be before any gcode lines with an "E" extrusion. What firmware is the printer running?
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
GregValiant 1,142
