I did try the "Print thin walls". I'm using a 0.4mm nozzle, but this appears to be a slicing issue, not a printing one. I'm new to this - is there a way to tell the slicer what nozzle size I'm using?
Yeah, if I drop the line width settings all the way down to 0.1mm I get this instead. Really not an ideal solution because the nozzle is still printing 4 separate walls and then filling in the gaps between them. I've seen this gear printed (bought them on eBay) but I don't understand how they're being done. My guess is that it's a redesigned gear.
I think so too, the design is not very good and even you could print it in some way it will easily break.
Smithy 1,145
Have you tried the option "Print thin walls"?
Which nozzle size do you use?
