academy.ultimaker.com
sBenjamin
Posted · academy.ultimaker.com
In Cura 4.9, the Top/Bottom settings moved from the Shell category to a Top/Bottom category.
Pro-tip: there's a search field on top of the settings list. You can type the name of a setting there.
      • 27 replies
