Random holes/gaps appearing in model after slicing
Posted
· Random holes/gaps appearing in model after slicing
The cause of this is probably that the walls are too thin. You could use print thin walls. Or use Arachne, there I could slice it perfectly, because of the variable line widths. See here:
Posted
I did some research after posting this and did try thin walls but it'd only print a weirdly shaped inner-wall and not the outer-shell like it's supposed to, but I was unaware of Arachne so I'lll look into that. Thanks!
fvrmr 73
Here you can read more about our Arachne Engine: https://github.com/Ultimaker/Cura/releases/tag/Arachne_engine_beta
samakhoul 0
