HELPReplace Stock UM3 NFC board with PN532 Breakout Board
So, I figured it out. I was under the assumption that the pin order on the NFC board went left to right, row by row, but it was in card top to bottom, column by column. Attached is the proper pin order when looking at the ends of the cable. I figured out the mistake by using a multi-meter to figure out which pins matched on either end of the cable, since the pin layout was only described on the schematic on the mini-din 9 pin end.
Monroe07 8
