Yes, that was it! However it looks to be very glitchy/spotty if it were to try and print. Even with the wall thickness increased it still appears glitchy. I remodeled the actual model to give the form an inner wall and outer wall which solved this issue. Print time is doubled but at least I'll have the detail at the top.
Thanks
Smithy 1,145
There are several possibilities, but it could be an error in the model itself or the wall thickness is very thin.
Try to enable "Print thin walls" and if you still have this error, then check your model.
