Cura plugins
atelierfat
Posted · Cura plugins
Hi there, I have installed Cura on my mac and tried to add some plugins no go! It doesn't load although it says that the plugin was added even after restart it simply doesn't exist any ideas please?
    We really need more information to help you. What plugin(s) did you install? Did you restart Cura after installing the plugins? Post a link to your Cura.log, which can be located via Help -> Show configuration folder.
        • 27 replies
