Posted · What kind of paint?
I’m going to be printing out stuff for my kid with white PLA and was wondering what type of paint adheres well to it and if a primer coat of some type be a good idea too?
    Water based acrylics used by plastic model builders works well. The usual Vallejo, Games Workshop, ArmyPainter paints  etc.  I'd use a primer, yes.. couple of 3-4 coats of filler/primer spray and a bit of sanding also gets rid off layer lines. Check automotive primer spray cans.
    If your kid is still young enough to stick everything in the mouth, maybe even consider a food safe resin coating on top.
