Restart at beginning of print
Jimoon
Posted · Restart at beginning of print
I have an Ultimaker 3. Every time I start a print (both over network or via USB from cure) the printer just restarts itself.
Im hoping you can help.
Many thanks
    Sounds like your power supply has a problem and as soon as the bed starts to heat up, there is not enough power and the printer reboots.
    you could check when you start a print without heating the bed if it is better.
