How to print as "Support Mesh"? Not visible in "Per Model Settings".
Posted
· How to print as "Support Mesh"? Not visible in "Per Model Settings".
Thanks, it worked great by the way. Using Blender I made a vertical projection down to zero elevation of the part that needed a support so that it exactly matched the top-view silhouette of the overhang. Worked excellently and meant that I didn't have to use really excessive support generation settings that were adding all sorts of little bits around the model on tiny overhangs that wouldn't have printed properly.
nallath 1,124
The second button does that 🙂
curaMatt 1
