Sending files through USB - Sovol SO-1
Posted · Sending files through USB - Sovol SO-1
I need to be able to send files to my Sovol SO-1 plotter through USB and need help. It has a micro SD port and a micro USB port. If im not able to use it using this board, does someone have a controller I can buy that will work with USB?
Here is a link to the manual:
SO-01说明书v1.cdr (shopify.com)
    I don't understand.  You want to print over the USB or you want to send files to the SD card (very slow) and then print from the SD?
    It has a USB port, just plug it into your computer with a data capable USB cord.
