Sometimes Profiles show up, sometimes not
ADmakes
Posted · Sometimes Profiles show up, sometimes not
Cura 4.10
Sometimes when I open a model the default profile will have the same name as the last profile I was using, but the actual settings are different (print speed, temp, etc.). When I click the drop down menu to select a different saved or default profile, there are no options. Nothing. The defaults (standard, dynamic, super quality) aren't even there.  Just one option, with the name of the last custom profile I created, but with incorrect values.
Usually I just quit all instances of Cura and restart, which seems to correctly load all my profiles, but what is causing this?
    just bumping this thread in hopes of some suggestions. Its getting really annoying that I have to keep restarting Cura and reloading a model to get my profiles to show up.
    Any suggestions?
    • 1 month later...
