Changing project crashes cura
Ch3vr0n
Posted (edited) · Changing project crashes cura
This a basic temp tower. Trying to make the following changes to the file
> change existing "change at Z layer" entry 2 from layer 9 to layer 1
> add "change at Z", change at layer: 2, set fan speed: 100 and move that to the bottom
> move "create thumbnail to the bottom"
> add "display progress on LCD" with percentage enabled
> set "change at Z" script to 3rd from the bottom
> change z-seam position to "user specified": back
> set bottom initial layer to "lines"
File > save project > spins for a minute > Cura crashes, every single time.
*Been trying save these changes for the past half hour* Crashes EVERY DAMN TIME. I don't care how long it takes me. I will make those changes. It sure as hell isn't my system. 9900k, 32gigs of ram, samsung 970 Evo plus 1TB as boot drive (where cura is installed)
cura.zip
Edited by Ch3vr0n
    Takes a moment (no spinning cursor), but saved on the first go. I like/want/need those thumbnails though.
    just for some extra info, exporting gcode isn't a problem with thumbnails enabled.
    Edited by Ch3vr0n
