Print in place parts are always a tough task for any printer. Fortunately Cura (at least the newer versions) has an adjustment that can really improve dimensional accuracy. You may have to search and turn them on, but I know they are available when "Expert" settings are selected. There are 3 of them, and all can be found by searching "expansion".
Horizontal Expansion is the first of the 3. This adjust all polygons in a layer to "shrink" or "expand" them. Negative values will bring polygons in towards the meat of the part (smaller outer dimensions, larger inner dimensions). I have this set to -0.125mm.
Initial Layer Horizontal Expansion is next. This functions the same as the first setting, but only on the initial layer. I have this set to -0.2mm to get rid of "elephants foot".
Last is Hole Horizontal Expansion. This is another similar setting but only applies to "holes" in the part. This setting also is valued inversely, so positive values give larger inner diameters, and negative values will shrink holes. I have this set to +0.15mm.
These settings give me the best dimensional accuracy that I have found. I am usually within +-0.1mm tolerance. These settings may or may not work with what you are trying, but will give you a starting point. With a pair of calipers and some calibration models, you can adjust from stock, or from these values as needed.
FRabe 5
