7 hours ago, nallath said:I don't understand what your issue is. The area that you circled just has ironing moves over the walls. If you don't want that, disable ironing.
The issue is the visually distinct difference between the walls and skin on the printed object, which I was trying to solve with ironing when I took the screenshot. The top surface is one single layer, so I expected it to look smooth and clean, but instead the walls form a visual border around the skin.
Printed on UM3 with Ultimaker ABS using default cura "Normal" profile with .3 layer height:
(*1 the little round blemish highlighted in yellow is where the print finished)
(*2 flash used for emphasis)
vs same model, same printer, same material, ironing, manual hackery of the gcode, but I forgot to enable monotonic surfaces.
Edited by kfsone
nallath 1,104
