tinkergnome 929
I see - the former "Shell" section is splitted into "Walls" and "Top/Bottom". The change happened in Version 4.10 (as far as i can see).
But anyway - i work a lot with the filter function in Cura , that's usually the fastest way to find relevant settings.
tinkergnome 929
Well in Cura there are settings for "Walls" and "Infill" (among many others) - is it this what you're looking for?
In case you haven't found it yet - there's an online manual for Cura - quiet comprehensive.
Maybe switching to custom print settings is needed first?
https://support.ultimaker.com/hc/en-us/articles/360012028419-How-to-use-the-custom-print-settings-in-Ultimaker-Cura
