The build plate in Cura is a "virtual" build plate that is "MachineWidth" x "MachineDepth" as you set them in Machine Settings. The 0,0,0 is usually at the left front corner for most cartesian printers. When Cura generates a gcode the X Y Z locations are calculated from that origin. Cura will take into consideration the distance between the nozzles and note the areas of the build surface that they can't get to.
When a gcode file is read by (most) printers, the printer puts the 0,0,0 of the gcode file (the virtual build plate) at the Home Offset 0,0,0.
The Auto-Home position is measured from the Home Offset 0,0,0. That means that when you Auto-Home the print head it should read something like X=-5 Y=-3 Z=0. That is where the nozzle is in relation to the Home Offset 0,0,0. I know it isn't intuitive, but it's the way it works. The Auto-Home 0,0,0 is not absolute, it's just a position where it is up against the switches. If you change the Home Offset position then you change the location of the Auto-Home position.
For a dual head machine there is a distance between the nozzles? That should go into the Machine Settings on the Extruder tabs.
I'm excited because I've personally produced this showcase event, so if you are curious what else I'm up to nowadays, come check it out and say hi in the chat! It would mean a lot!
GregValiant 702
