4 hours ago, rodney007 said:I think thats a bit misleading.
I paid good money for an upgrade and at this stage its a downgrade!
Can I ask you why you're coming here to complain? You did not pay Ultimaker for your upgrade, did you? Do you feel that Ultimaker misled you?
- 2
GregValiant 1,351
You can create a printer in Cura by using the generic FFF printer definition (under non-networked printers / Custom) and going into the Machine Settings and changing things like: The name, the build plate size, the Firmware Flavor, StartUp Gcode, Filament diameter, etc.
One issue that I recall has come up is the Maximum Temperature. It is defined as 365° in the fdmprinter.def.json file and imposes that limit on the temperature setting in Cura. You could alter that file or create a definition file of your own that overrides the Maximum setting to match your printers Max Temperature.
