How to switch printers in a project without the project settings getting overridden?
Posted · How to switch printers in a project without the project settings getting overridden?
I have a project open, I slice then send to a connected printer.  I want to then quickly switch printers in the project and send the same print to that printer.  Trouble is when I switch printers the project settings change.  Is the a way to freeze the settings?
    If the printers are of the same type, currently the best solution is to reload the project file.
    We are working on a better flow for this.
    Hi Thanks for replying, yes this is what I have found myself doing but wasn't sure I was using the most appropriate workflow.
