Are my settings clogging the nozzle?
giugni
Posted · Are my settings clogging the nozzle?
Hello all guys,
Recently I have compared the extruded filament width of a new nozzle and after 50h of printing
when the nozzle (0.8mm) was new, the filament width after extrusion was about 0.86mm
after a 48h print I have measured again and it was extruding a filament of 0.6mm causing under extrusion
the first time I have seen that, I thought the nozzle worn out after few months
but last week I changed two nozzles because of this reason
even with 2-3 cold pull using transparent nylon, the new nozzles still clogged
(the outside the nozzle is often cleaned with a brass brush)
so, I am wondering if my settings are too much to handle by the extruder/nozzles:
I have come up with these settings for print a tube-like shape that must be the most rugged as possible, I don’t mind the bad-looking surface because the pieces are machined in a lathe.... I have followed the suggestions of CNC Kitchen, Teaching Tech, Maker's Muse, MatterHackers to print with 0.8mm nozzle in the most tough way possible:
- over extruding (120-130%)
- high temperature (240°C)
- large line width (1mm)
- no cooling
- low speeds (16-25mm/s)
and so on...
(settings file attached)
Cura is measuring a max flow rate of 9.75mm3/s in the infill and a minimum of 6mm3/s in the external wall
for any additional information please ask  🙂
thanks a lot
creatbot F430 - piena+vetr+infill step.curaprofile
        • 21 replies
