UlrichC-DE 110
I don't have a UM3 myself. However, it has also happened to me that the calibration of the switching was lost during the Firmaware update.
Downgrading the firmware does not help. You can calibrate the switch by heart via the menu and carry it out. Then everything should work again.
This is described in the printer manual. Otherwise, there is certainly a YT video or a link at Ultimaker.
To avoid downgrades, you can get into the habit of updating the firmware via USB in the future. This way you have all software versions to choose from.
Currently you can still download the 4.3.97.
https://support.ultimaker.com/hc/en-us/articles/360011587199
lancy 0
I want to downgrade the firmware. Where can I find the older stable firmware's ?
