spiralize doesn't work on CURA 4.11.0
kimura
  • 1 month later...
Posted (edited) · spiralize doesn't work on CURA 4.11.0
I opened the file and sliced it.  Spiralize was turned off.  The model sliced fine.  I turned Spiralize on and again, the model sliced as expected.
Sorry @kimura but I can't reproduce the problem.  Maybe it's your installation of 4.11???
This is as downloaded and there was concentric infill:
This is with spiral turned on
Edited by GregValiant
    On 10/25/2021 at 1:34 AM, GregValiant said:
    Use the File|Save Project command and post the 3mf file here.
    (The model needs to be solid thru and thru and NOT designed with thin walls)
    Download the latest version of Cura 4.12.1 solved the problem.
    Edited by kimura
