Posted (edited) · In Cura (older version) I print much faster than in Cura 4.11
Hi everybody.
Lately I 'moved' from Creality Slicer 1.2.3 (which is based on some older version of Cura) to Cura 4.11.
I wanted to print the base from this drill stand.
In the older Cura (Creality Slicer 1.2.3) estimated printing time was around 7 hours.
In Cura 4.11 estimated printing time was around 18 hours!!!
Why is this happening? How can I make the Cura 4.11 create faster code, as fast as the older version's?
In both, layer height and fill density was the same.
In the older version I use the profile quoted in the end of my post.
In Cura 4.11 I use no profile, I have simple selected Esun PLA plus as material.
(printer: Ender 3 Pro)
Quote
[profile]
layer_height = 0.15
wall_thickness = 1.2
retraction_enable = True
solid_layer_thickness = 1.2
fill_density = 15
print_speed = 50
print_temperature = 215
print_temperature2 = 0
print_temperature3 = 0
print_temperature4 = 0
print_temperature5 = 0
print_bed_temperature = 60
support = Everywhere
platform_adhesion = Raft
support_dual_extrusion = Both
wipe_tower = False
wipe_tower_volume = 15
ooze_shield = False
filament_diameter = 1.75
filament_diameter2 = 0
filament_diameter3 = 0
filament_diameter4 = 0
filament_diameter5 = 0
filament_flow = 100
nozzle_size = 0.4
retraction_speed = 80
retraction_amount = 6.0
retraction_dual_amount = 16.5
retraction_min_travel = 1.5
retraction_combing = All
retraction_minimal_extrusion = 0.0
retraction_hop = 0.0
bottom_thickness = 0.3
layer0_width_factor = 100
object_sink = 0.0
overlap_dual = 0.15
travel_speed = 60
bottom_layer_speed = 20
infill_speed = 0.0
solidarea_speed = 0.0
inset0_speed = 35
insetx_speed = 35
cool_min_layer_time = 5
fan_enabled = True
skirt_line_count = 1
skirt_gap = 3.0
skirt_minimal_length = 150.0
fan_full_height = 0.0
fan_speed = 100
fan_speed_max = 100
cool_min_feedrate = 10
cool_head_lift = False
solid_top = True
solid_bottom = True
fill_overlap = 15
perimeter_before_infill = True
support_type = Lines
support_angle = 60
support_fill_rate = 15
support_xy_distance = 0.7
support_z_distance = 0.15
spiralize = False
simple_mode = False
brim_line_count = 20
raft_margin = 5.0
raft_line_spacing = 3.0
raft_base_thickness = 0.3
raft_base_linewidth = 1.0
raft_interface_thickness = 0.27
raft_interface_linewidth = 0.4
raft_airgap_all = 0.0
raft_airgap = 0.22
raft_surface_layers = 2
raft_surface_thickness = 0.27
raft_surface_linewidth = 0.4
fix_horrible_union_all_type_a = True
fix_horrible_union_all_type_b = False
fix_horrible_use_open_bits = False
fix_horrible_extensive_stitching = False
plugin_config =
object_center_x = -1
object_center_y = -1
[alterations]
start.gcode = ;Sliced at: {day} {date} {time}
    ;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
    ;Print time: {print_time}
    ;Filament used: {filament_amount}m {filament_weight}g
    ;Filament cost: {filament_cost}
    ;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
    ;M109 S{print_temperature} ;Uncomment to add your own temperature line
    G21        ;metric values
    G90        ;absolute positioning
    M82        ;set extruder to absolute mode
    M107       ;start with the fan off
    G28 X0 Y0  ;move X/Y to min endstops
    G28 Z0     ;move Z to min endstops
    G1 Z15.0 F{travel_speed} ;move the platform down 15mm
    G92 E0                  ;zero the extruded length
    G1 F200 E3              ;extrude 3mm of feed stock
    G92 E0                  ;zero the extruded length again
    G1 F{travel_speed}
    ;Put printing message on LCD screen
    M117 Printing...
end.gcode = ;End GCode
    M104 S0                     ;extruder heater off
    M140 S0                     ;heated bed heater off (if you have it)
    G91                                    ;relative positioning
    G1 E-1 F300                            ;retract the filament a bit before lifting the nozzle, to release some of the pressure
    G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more
    G28 X0 Y0                              ;move X/Y to min endstops, so the head is out of the way
    M84                         ;steppers off
    M81
    ;{profile_string}
start2.gcode = ;Sliced at: {day} {date} {time}
    ;M104 S{print_temperature} ;Uncomment to add your own temperature line
    ;M109 T1 S{print_temperature2} ;Uncomment to add your own temperature line
    ;M109 T0 S{print_temperature} ;Uncomment to add your own temperature line
    G21        ;metric values
    T1                      ;Switch to the 2nd extruder
    G1 F200 E10             ;extrude 10mm of feed stock
    G1 F200 E-{retraction_dual_amount}
    T0                      ;Switch to the first extruder
    G1 F{travel_speed}
    M117 Printing...
end2.gcode = ;End GCode
    M104 T0 S0                     ;extruder heater off
    M104 T1 S0                     ;extruder heater off
    M84                         ;steppers off
    ;{profile_string}
start3.gcode = ;Sliced at: {day} {date} {time}
    G21        ;metric values
    T2                      ;Switch to the 3rd extruder
    G1 F{travel_speed}
    M117 Printing...
end3.gcode = ;End GCode
    M104 T2 S0                     ;extruder heater off
    M84                         ;steppers off
    ;{profile_string}
start4.gcode = ;Sliced at: {day} {date} {time}
    ;M109 T2 S{print_temperature2} ;Uncomment to add your own temperature line
    G21        ;metric values
    T3                      ;Switch to the 4th extruder
    G1 F{travel_speed}
    M117 Printing...
end4.gcode = ;End GCode
    M104 T3 S0                     ;extruder heater off
    M84                         ;steppers off
    ;{profile_string}
support_start.gcode =
support_end.gcode =
cool_start.gcode =
cool_end.gcode =
replace.csv =
preswitchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
    ;This code is added before the T(n)
postswitchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
    ;This code is added after the T(n)
Edited by panoss
    Ok, I think I found it.
    I had selected as printing material eSun PLA +.
    I changed to Generic PLA and time reduced to 6 hours and 10 minutes!! (in 4.11)
    I suppose some parameter in eSun PLA + must be the reason...
    Edited by panoss
