Couple issues with UM3 printer connecting
Tiger91
Posted · Couple issues with UM3 printer connecting
I've got a few major issues.
Recently, I had trouble connecting my UM3 to my computer via wi-fi.  Nothing I was doing worked, and when I went to open the comms center box, I noticed that the antenna wire had come off.  Not only that, but when I try to connect an ethernet cable from my PC to my UM3, it won't register.
How do I solve these issues?  I just want to connect, so the lan problem would be the one need the most help on.  The antenna looks a bit more serious, and I would like to know if any special materials or techniques are required to solder the connecter back on.
