On 11/13/2021 at 4:26 AM, reble said:I end up with the following error message "Add a network printer, there is no printer on your network, add a non network printer"
That is not an error. You can add a Non-networked printer in that same dialog.
The networked printer options only work for Ultimaker printers.
On 11/13/2021 at 4:26 AM, reble said:When I start the 32bit version I get the following error message: "could not initailze OpenGL. This program requires OpenGL 2.0 or higher. please check your video card drivers"
That is an error. I looked up your laptop, and it seems to have an integrated Intel HD Graphics 4000 GPU. This should be enough to let Cura run, albeit not fully featured. However, when asking your system if it can use OpenGL, your system says "no" to Cura. This is indicative of a problem with the GPU driver. What GPU driver do you have installed? It could be that Intel has a newer driver (even if it is not specific to your laptop, it probably works).
reble 0
I still have the Gateway laptop model NV570P-18U as a backup computer. But now I also have as my primary computer, a Gateway tower model FX-6840. The Toshiba Satellite L455-S5000 laptop kicked the bucket.
