reg: 3d Printing material
Posted · reg: 3d Printing material
I am from india
1.I have a question in selecting machine and material
a) I have a one component name is Brakeshoe which is doing in casting (Grey cast iron),Now i  want to create the same in 3d printer .
b) I would like to know what type of ultimake machine will support.and what type of material i can use in 3d print instead of grey cast iron
c) material properties should not change or give better result than the grey cast iron.
I have attached the brakes shoe image for your reference  Please give me solution .
Thanks and Regards
K.Suresh kumar
MOB-+91-9003092350
MAIL-sukrkskram@gmail.com
