Can't get firmware to upgrade after install of UM2 extrusion kit
Benziger
Posted · Can't get firmware to upgrade after install of UM2 extrusion kit
I have a seven year old Ultimaker 2. I just installed the UM2 extrusion upgrade. All went well. Only thing off was that original UM2 did not have ferric core around the motor wires. Tried to use Cura to upgrade the firmware and there was not 'Ultimaker 2' choice. Tried the UM2 Connect version and unit does not turn on normally. Front display stays black. Don't know what to try next. Any suggestions appreciated.
    After the extrusion upgrade, you have an UM2+, so the FW for UM2+ should work. I think it is also important that you add your printer also as UM2+ to Cura.
    The UM2+ Connect is completely different and I am wondering that you were able to install the FW of it. The UM2 has an Arduino board and the UM2+ Connect is using Linux.
    So I would try to add a new printer UM2+ to Cura (use Extended if you have an Extended) and then try again to upgrade the firmware.
    Thank you Smithy,
    Very prompt and helpful ideas. I had success today when I spoke with Tony Harris at fbrc8 support. He diagnosed a loose connection of a flat cable from the front display. I opened it back up and voila, one of the cables had come loose. Got that seated and the um2 works well now. A big relief. Thanks again. John
