GregValiant 956
The model is watertight, but there are problems. A lot of character models are scanned or developed from 2d representations. Scanning in particular depends much on the software that translates the 3d point cloud into a model.
In this case, one problem is at the shoulder where there is a gap between the collar and the hair. The gap causes a very narrow wall and Cura is having trouble slicing it.
The cape is a problem in a lot of spots. Here is an image of the bottom portion. You can see the gap and the single wall extrusions that are basicly hanging in air (when sliced with your printer and settings). That would print, but would come off with the support.
So there are going to be issues when you print this. I switched from your printer to my Ender and even with a .1 nozzle that area is not good.
SomeDudeOnTheNet 0
Here are the project files if they are needed.
CFFFP_Twisted_Fate.3mf
