Hello! Could you please also comment on JQuery and nginx ( outdated versions ) for 7.0.0.0 ( Ultimaker S5 ). We are also have complains from our IT department due to firmware vulnerabilities. Will it be updated in the next patch? Thank you!
Edited by esertuk@esertuk Just like @CarloK said above none of our printers are using the configuration option that allows for that particular exploit, so we are not rushing to include a new version. Nor are we currently aware of any CVE for nginx that we do expose our users to since all require specific configurations we don't use). We do asses security concerns on an ongoing basis, I imagine you could contact support and request our latest security assessment documentation.
I think the Jquery CVE's concerning XSS are a valid concern (albeit with the low impact of at worst (re-)starting a print, not retrieval of information AFAIK).
The S3 and the S5 have the option to enable the firewall, you can still use the cloud platform if you do but none of the software running on the printer is exposed to attackers on your internal network. This should alleviate any concerns from your IT department.
Edit: Adding up-sell, FTW? 😛
If your organization subscribes to Ultimaker Essentials your IT department can block access to the printer settings by configuring a pin code and enable the firewall on all printers remotely.
// Now I feel dirty, you can just enable the firewall and tell everyone to leave it on.
adding the up-sell
CarloK 204
@noverby Thanks for bringing this to our attention. We checked the vulnerability and it's only applicable when a certain configuration option in nginx is active. In our UM3 printers that option is not present, so this CVE is not applicable.
I'll make a note to update nginx in a next release, but because it has no impact on our printers we won't rush a new release.
noverby 0
Thanks @CarloK!
