Super, thanks a lot for the reply
I try that this evening
OK, Slicing works.
It also made version 14.01 which is great
But now Printing still doesn't work.
Any sugestions on that, by any chance :?:
OK, Slicing works.
Any sugestions on that, by any chance :???::
Well, I am always printing from the SD card, so I did not check. You probably can start Cura in a terminal and check what it tells you.
I think there were issues with Linux + Python and 250K bauds speeds (a near but non-standard speed b/c of the limitations of the Arduino that powers the printer). A year ago it had to be 115.2 and I think Marlin had to be re-compiled appropriately(!). I cannot state about it right now, I would hope the bug is fixed by the time!
Hello Jeremie,
I did something wrong .
Could you please you please explain the make part
I downloaded the zip from https://github.com/Ultimaker/CuraEngine as CuraEngine-master.zip and unpacked it.
Then I lost you.
I need to cd to CuraEngine-master and then ....i'm lost; no idea what to do next.
Can you help out again please :oops:
jeremie 13
In fact, the package is broken. It happens regularly with Linux because the author better implements features than packages (which is a good thing!)![;)](//content.invisioncic.com/ultimake/emoticons/5a33abe00be82_1f609copy.png)
I fixed the last issues by installing the *deb like you did, and then compiled the source code of the slicer (downloaded from github). Then I overwrote the existing slicer executabl (was either absent or made for 64 bits).
I just wrote step-by-step instructions it in my blog if you need: http://www.tridimake.com/2014/01/fixing-cura-broken-linux-packages.html
