I have tried this already, no luck. Also the up and down commands from the maintenance\calibration\switch is not working.
cheers Ertan
cheers Ertan
What do you mean with up down commands? Do you mean to raise/lower the bed?
For the calibration of the switch there is afaik no up/down command.
there are commands in calibration menu, where you can bring you printcore 2 up and down. What can be the reason for this faulty behavior?
Cheers Ertan
I have to check it later on my S5, but as far as I can remember from the last calibration, you do all the steps in the calibration process manually. So you start recalibrating in the menu and then follow the instructions there. You have to manually switch the cores with the side switch on the print head, then move the head by hand to the right side that the lever fits into the slot and so on.
Here are the instructions from the UM support site:
Smithy 1,134
You can manually recalibrate the switch process. Check the menu, somewhere under maintenance and follow the instructions there. I guess that will solve your problem and the switch should be work again.
