Many thanks for the reply, please find attached the Cura log files.
6 hours ago, nallath said:You have the same issue as
It seems that your SSL certificates aren't correctly updated
I have checked and I see no out of date or invalid certificates, and Cura is the only connection I have this issue with, It used to work up to a few weeks or so ago.
I have been doing lots of investigating today and can see or find no reason other than the release of 4.12 which was around the time this starting happening, I think something has been changed at your database end which can also cause the SSL connection issues.
Edited by Washac
nallath 1,100
We are not blocking older versions of Cura from accessing the marketplace.
Could you share your log files?
