Plugin
kstorck
Hi All,
I'm new to the 3D world. And I hope to can get some help with the following question.
Is there a plugin in cure where the print can get text on itself, for example a name or number.
Thank you 🙂
    There are other programs (MS 3D Builder is one) that will allow you to add text either raised or embossed to your STL file.  3D Builder is a bit non-intuitive but after a few tries I get it to work.  The text follows any contour as well.
    I shamelessly named this boat after myself.
    • 1 month later...
