Thanks for the reply. It is not because of minimum layer time. - I have adjustet this setting already and it would also show up in the preview.
If you look at the video, it is random speed changes.
Horizontal Expansion Bug
GregValiant 949
I looked at the video before I made my previous post. Videos are interesting but don't give any real information. That comes from project files and gcode. With only the video all I can say is "Yep. That's how it looks ".
GregValiant 949
A project file would be good. Load the model and choose your settings then select "File | Save Project". Post the 3mf file here.
The speed will be reduced whenever Minimum Layer Time comes into play. The default is 10 seconds and is to allow sufficient cooling for each layer. A related setting is Minimum Speed.
