S5 wont Load/Extrude certain filaments
RodBot
Posted · S5 wont Load/Extrude certain filaments
Had been using unsupported materials, setting them up in Cura, it was all going fine. Then for some reason, the filaments won't extrude on loading, almost seems like the print core is not getting hot enough? I've cleaned and cleaned and if I go back to PLA or a supported material then it works.
I can get a PC+CF to load/extrude load. But two kinds of Nylon+CF and a support material won't extrude on loading or printing. And I had that support material working perfectly. It all started after I went into setting and added/updated the materials in Cura, I think that is what caused it.
What went wrong?
