47 minutes ago, GregValiant said:Under Mesh Fixes see if "Remove all Holes" is checked. It has it's uses but it's for very specific cases so you need it unchecked for that model. While you're there make sure "Make Overhangs Printable" is also unchecked or you will lose the horizontal hole as well.
It is not checked. I have uploaded the STL file for you to play with.
GregValiant 949
Edited by GregValiantLink to post
