How do you adjust the X and Y axis? Ultimaker Original
Posted
· How do you adjust the X and Y axis? Ultimaker Original
As far as I can remember, the Ultimaker original has endstops on both ends of the axes. If properly connected, the endstops should signal the firmware that the head has reached the end of an axis. There is nothing to adjust.
(those two bolts on the top-left need to be fixed though; you might be missing two nuts on the other end of those)
ahoeben 1,955
