7 hours ago, g_von said:I remember a year or two ago
Things may have changed in your network (or eg in the firewall software you may use).
Then again, it is always possible that I did something wrong in the plugin. Could you go to Help -> Show configuration folder, locate the Cura.log file and upload that somewhere I can have a look (eg dropbox, google drive, etc)?
ahoeben 2,047
The Cura OctoPrint Connection plugin uses (a pure-python implementation of) Bonjour aka Zeroconf to detect OctoPrint instances on the network. There are networks where this does not work reliably. In that case you may have to use the "Add" button to add your instance the to list. You can enter the IP address of the OctoPrint instance, or the hostname if that works in your browser.
I don't use that service my self, but I don't see any reason why it would not work.
g_von 0
Thank you, I'll try adding it manually.
I remember a year or two ago I was able to add OctoPrint (on an older version of both Cura and OctoPrint) using the Refresh search.
