GregValiant 1,330
There was at least one printer definition file that had the Support Wall Count and the Support Density set to "0" if tree supports were selected. If a user would switch to tree supports the settings would go to zero and there would be no tree - just the brim.
What printer do you have? I can't remember which one had the problem.
hmmm_okay 0
This also happened to me recently. For some reason 'support wall line count' kept defaulting back to 0. It should be 1. Hope you found this solution!
