https://support.ultimaker.com/hc/en-us/articles/360011733980-The-Ultimaker-Cura-workflow-explained
And section on Layer View. I don't see item 9. Start Simulation
The good news is that the "simulation" in the preview tab has nothing to do with whether your printer is connected or not.
The bad news is that if the horizontal slider and the "play" button are not there, your layer view is probably in "compatibility mode", which likely means that you are looking at a "watered down" version of layer view because your GPU (or the driver) does not support required functionality for the normal layer view.
Thanks. I'll investigate the GPU/driver issue.
Edited by geewizard
ahoeben 1,721
What do you mean by "Start Simulation menu choice"?
