Something worng on my slicing
Themode
Posted · Something worng on my slicing
The most common reason is that in the Mesh Fixes settings "Remove All Holes" is enabled.
Both "Remove all holes" and "Make Overhangs Printable" are for very specific conditions that don't come up often.  Neither setting should be enabled unless you have a model that really needs them.
    Posted (edited) · Something worng on my slicing
    Not in Blender...in Cura.
    Above all the Cura settings is a search box.  To the right of the search box is an icon with three lines on it.  Click on that icon and set visibility to "All".  Then go down to the Mesh Fixes section and make sure "Remove all Holes" is de-selected.
    Edited by GregValiant
