@GregValiant hum and where i can find that setings on blender?
GregValiant 1,288
Not in Blender...in Cura.
Above all the Cura settings is a search box. To the right of the search box is an icon with three lines on it. Click on that icon and set visibility to "All". Then go down to the Mesh Fixes section and make sure "Remove all Holes" is de-selected.
Edited by GregValiantAh nice i see.
Thx for the help is fixed now ^^
GregValiant 1,288
The most common reason is that in the Mesh Fixes settings "Remove All Holes" is enabled.
Both "Remove all holes" and "Make Overhangs Printable" are for very specific conditions that don't come up often. Neither setting should be enabled unless you have a model that really needs them.
