Posted · Need help with 'make overhangs printable'
So here's where I am sitting. I have this model that I ran 'make overhangs printable' on and I like what it did to change the model. But it still needs support. I have not found a way to have it change the model And place supports. So I was thinking if I could get it to give me the model With the changes baked in then I could reslice it with supports on. Any one know if this is possible? I will attach the model if any one wants to play around with it.
Thank you for your time
Aggro
halloween-bottom-flat-base.stl
