Once again sir, a big THANK YOU..
I will download and have a look shortly.
What's the difference with the full blown version. If it's available I wouldn't mind a copy. Thanks
Regards
Regards
There's just more stuff in it and a larger interface. I think it works a bit better with touchscreens. This is a screenshot of the main page. It has tools for recovering a botched print as well as starting a print from any point within a gcode file. You can store macros, run multiple printers from the single instance of the program, adjust settings in the printer like steps/mm, Home Offset, Accel and Jerk...stuff.
Edited by GregValiant
Thanks
I've only just got back in. Had a bit of an urgent place to be, I'd forgotten, till my calendar reminded me.
Will be on to both after late lunch.
Thanks again.00
Regards
GregValiant 697
My solution. This one is the short version. I have a full blown one as well.
There is a readme file included in the Zip. The app is unsigned and you will probably have to fool your anti-virus/firewall into allowing you to install it.
Let me know if you have issues.
Gregs SD Print Tool.zip
