Cura makes trouble (double line) with small surface object (or big nozzle)
Posted
(edited)
· Cura makes trouble (double line) with small surface object (or big nozzle)
Even if just "Fill gaps" is used, Cura produces some scattered lines, messing up the form. I can’t comprehend why reduced flow line (Compensated Wall Overlaps) has some “bubbles” along the path, reminds me on messed up PID controller, especially on a curved path. Nozzle goes around touching some points of the line, without much influence, except extruder/filament flow disturbance.
The best result I got with halved inner wall thickness. But then extruder flow can’t be regenerated in time to properly start full sized outer wall.
Edited by Torpedo123456
Torpedo123456 0
